查看: 3490|回复: 6
[专题贴] NORIT AirLift MBR
发表于 2008-9-13 17:24:47 | 显示全部楼层 |阅读模式
Abstract
The Ootmarsum wastewater treatment plant (WWTP) is owned by the water authority Regge & Dinkel
(WRD) and is situated in the municipality of Dinkelland (eastern part of The Netherlands). The WWTP must
be modernised, because it discharges the treated wastewater into a water system with considerable ecological
vulnerability. In the restructuring plan the urban water chain/cycle was integrated into an ecological water
management approach.
In cooperation with Grontmij engineering consultants a design study was carried out resulting in the choice
for a so-called hybrid system. Such a system combines a conventional system followed by a sand filter with a
membrane bioreactor (MBR). With a hybrid MBR, the costs can be reduced relatively to those of a complete
MBR plant without making concessions in terms of effluent quality.
After an intensive selection procedure NORIT Membrane Technology (NMT) was selected with the novel
NORIT AirLift MBR system. The construction work of the 650 m3/h plant started in mid-2005 and will be
completed by late 2006; start-up of the full scale will be early 2007.
As preparation for the full scale plant operation an intensive pilot study is currently being performed in
order to develop a start-up protocol, to train operators, to check control philosophies, and to optimise the
overall processing.
发表于 2008-9-23 09:57:03 | 显示全部楼层
这是好东西,呵呵,谢谢楼主
发表于 2008-9-26 09:55:53 | 显示全部楼层
楼主太强了,在哪里找到的资料?
发表于 2008-10-6 17:58:19 | 显示全部楼层
刚下载了,全英文的,感兴趣的可以看看
发表于 2008-11-25 19:28:00 | 显示全部楼层
楼主  你怎么有这的啊  这是NORIT的主打产品  说是能耗很低的
发表于 2008-12-2 14:37:41 | 显示全部楼层
学习一下!应该会用得到的
学习一下!应该会用得到的
发表于 2010-5-11 23:28:03 | 显示全部楼层
谢谢分享!这资料太好了……
GMT+8, 2025-2-1 11:56 , Processed in 0.046629 second(s), 17 queries .
