1、The operating temperature is measured at the surface of the heating chamber,between insulation and heating chamber.
2、If this can not be avoided it is recommended to install either an simple thermostat close to the inlet which switches OFF the VOD or a non-return valve between the contact system and the VOD.
3、The VOD be installed at a high location inside a building near the contact chamber or process point where the exhaust is being
ischarged.
4、In addition, it should be ensured that the dissipated heat does not lead to any unacceptable temperature rise in the VOD room and that the installation corresponds to the safety regulations for areas in which ozone can be present
VOD:臭氧破坏器 |
