查看: 676|回复: 0
[原创类] 环境会影响红外测温仪的选用和精确度
发表于 2013-4-28 10:49:08 | 显示全部楼层 |阅读模式
<!--[if gte mso 9]><xml>
<w:WordDocument>
  <w:View>Normal</w:View>
  <w:Zoom>0</w:Zoom>
  <wunctuationKerning/>
  <wrawingGridVerticalSpacing>7.8 磅</wrawingGridVerticalSpacing>
  <wisplayHorizontalDrawingGridEvery>0</w:DisplayHorizontalDrawingGridEvery>
  <w:DisplayVerticalDrawingGridEvery>2</w:DisplayVerticalDrawingGridEvery>
  <w:ValidateAgainstSchemas/>
  <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
  <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
  <w:Compatibility>
   <w:SpaceForUL/>
   <w:BalanceSingleByteDoubleByteWidth/>
   <w:DoNotLeaveBackslashAlone/>
   <w:ULTrailSpace/>
   <w:DoNotExpandShiftReturn/>
   <w:AdjustLineHeightInTable/>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
   <w:DontGrowAutofit/>
   <w:UseFELayout/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<p class="MsoNormal" style="mso-margin-top-alt:auto;mso-margin-bottom-alt:
auto;text-align:left;mso-pagination:widow-orphan" align="left"><span lang="EN-US"><a href="http://www.hcjyet.com" target="_blank"><span style="font-family:
宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:&quot;Times New Roman&quot;" lang="EN-US"><span lang="EN-US">红外线测温仪</span></span></a></span><span style="font-family:宋体;
mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:&quot;Times New Roman&quot;">所处的环境条件对测量结果有很大影响,应予考虑并适当解决,否则会影响</span>
<span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">测温精度甚至引起损坏。当环境温度高,存在灰尘、烟雾和蒸汽的条件下,可选用厂商提供的保护套、水冷却、空气冷却系统、空气吹扫器等附件。这些附件可有效地解决环境影响并保护</span><span lang="EN-US"><a href="http://www.hcjyet.com" target="_blank"><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;" lang="EN-US"><span lang="EN-US">测温仪</span></span></a></span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">,</span> <span style="font-family:宋体;mso-ascii-font-family:
&quot;Times New Roman&quot;;mso-hansi-font-family:&quot;Times New Roman&quot;">实现准确测温。在确定附件时,应尽可能要求标准化服务,以降低安装成本。当在噪声、电磁场、震动或难以接近环境条件下,或其</span>
&quot;Times New Roman&quot;">他恶劣条件下,烟雾、灰尘或其他颗粒降低测量能量信信号时,光纤双色测温仪是最佳选择。比色测温仪是最佳选择。在噪声、电磁场、震动和难以接近的环境条件</span>
&quot;Times New Roman&quot;">下,或其他恶劣条件时,宜选择光线比色测温仪。</span><span lang="EN-US"><br>
<br>
<br>
mso-hansi-font-family:&quot;Times New Roman&quot;">当</span><span lang="EN-US"><a href="http://hcjyet.com/html/cn/hcjyetproduct.html" target="_blank"><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;
mso-hansi-font-family:&quot;Times New Roman&quot;" lang="EN-US"><span lang="EN-US">测温仪</span></span></a></span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">工作环境中存在易燃气体时,可选用安全型红外测温仪,从而在一定浓度的易燃气体环境中进行安全测量和监视。</span><span lang="EN-US"><br>
<br>
<br>
mso-hansi-font-family:&quot;Times New Roman&quot;">  在密封的或危险的材料应用中,</span><span lang="EN-US"><a href="http://www.hcjyet.com" target="_blank"><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">通</span> <span style="font-family:宋体;mso-ascii-font-family:
&quot;Times New Roman&quot;;mso-hansi-font-family:&quot;Times New Roman&quot;">过窗口进行观测。材料必须有足够的强度并能通过所用测温仪的工作波长范围。还要确定操作工是否也需要通过窗口进行观察,因此要选择合适的安装位置和窗口材</span>
&quot;Times New Roman&quot;">料,避免相互影响。在低温测量应用中,通常用</span><span lang="EN-US">Ge</span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">或</span><span lang="EN-US">Si</span><span style="font-family:
宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:&quot;Times New Roman&quot;">材料作为窗口,不透可见光,人眼不能通过窗口观察目标。如操作员需要通过窗口目标,应采用既透红外</span>
&quot;Times New Roman&quot;">辐射又透过可见光的光学材料,如应采用既透红外辐射又透过可见光的光学材料,如</span><span lang="EN-US">ZnSe</span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;
mso-hansi-font-family:&quot;Times New Roman&quot;">或</span><span lang="EN-US">BaF2</span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">等作为窗口材料。</span><span lang="EN-US"><br>
<br>
<br>
mso-hansi-font-family:&quot;Times New Roman&quot;">  在环境条件恶劣复杂的情况下,可以选择测温头和显示器分开的系统,以便于安装和配置。可选择与现行控制设备相匹配的信号输出形式。</span><span lang="EN-US"><br>
<a href="http://www.hcjyet.com/" target="_blank">http://www.hcjyet.com</a>&nbsp;&nbsp;</span><span style="font-family:宋体;mso-ascii-font-family:&quot;Times New Roman&quot;;mso-hansi-font-family:
&quot;Times New Roman&quot;">红外线测温仪</span></p>
<watentStyles DefLockedState="false" LatentStyleCount="156">
</watentStyles>
</xml><![endif]--><!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
        {mso-style-name:普通表格;
        mso-tstyle-rowband-size:0;
        mso-tstyle-colband-size:0;
        mso-style-noshow:yes;
        mso-style-parent:"";
        mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
        mso-para-margin:0cm;
        mso-para-margin-bottom:.0001pt;
        mso-pagination:widow-orphan;
        font-size:10.0pt;
        font-family:"Times New Roman";
        mso-fareast-font-family:"Times New Roman";
        mso-ansi-language:#0400;
        mso-fareast-language:#0400;
        mso-bidi-language:#0400;}
</style>
<![endif]-->
GMT+8, 2025-2-1 07:55 , Processed in 0.044047 second(s), 16 queries .
