造纸废水脱色
以麦草浆为原料的造纸废水、经生化处理后,二沉池出水经过脱色处理后,回用于造纸生产。欲寻求二沉池出水脱色的有效方法,要求脱色率大于70%。
The wastewater comes from the process of the oaten paper's production, in which the oats is used as raw materials to produce pulp.
The wastewater treated by biochemical method should be deposited in the second depositor, and be decolored, and then it can be wtilized again in the manufacture of paper.
Now, the problem is that in practical application there is not a kind of economic and efficient decoloring manner in treating the wastewater from the second depositor.
Claim:decoloring rate of the method:>=87%
If you can help me, contact with SuchuanHui.
Tel:0531-8011598-8830
Fax:0531-8909641
